Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-27-2013, 01:03 PM   #1
bathtub
All the plumbing in the house drains except for the bathtub. i replaced all the old line that went to the maneline from the tub but it still will not drain.. any ideal
D-bolt is offline   Reply With Quote
Old 06-27-2013, 01:14 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 922
Pull the linkage out and make sure the plug is still attached if that is the style you have.
It may have fallen off and partially blocked the outlet.
Clean the trap
Old 06-27-2013, 01:32 PM   #3
i dont have one of those..
Old 06-27-2013, 02:09 PM   #4
The problem is most likely the waste arm. Remove everything including the P Trap.
Replace all of it.
Check the vent pipe. Ensure its clear
Drain Hot water only for one hour
If everything is draining but the tub then the problem is with the tub
Replace as much as you can
davidblackwoods is offline   Reply With Quote
Old 06-27-2013, 06:41 PM   #5
Rewards Points: 2,108
It has to be what you did not replace.
Old 06-27-2013, 07:05 PM   #6
MarginallyQualified
Rewards Points: 2,464
ain't it always like that?
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 07:03 PM
Bathtub Waste Exit Relocation nixplix Plumbing 1 04-29-2011 07:45 AM
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
