Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 07:31 PM   #31
Rewards Points: 22
Yes, good point that ddawg rasied in regard to using a vent stack. I've done that a number of times, and it can be the easiest way to go, but just skipped my mind earlier. Just stay safe, and don't go there if it's too steep or you are otherwise uncomfortable doing so.
Old 01-27-2013, 07:56 PM   #32
beginner50's Avatar
Didn't mention the house was built in 1915 so don't think that's a possibility but who knows! I'm gonna do what I can getting a snake tonight and do what I can! I do have another question! I do think its just clogged right behind my bathtub because that's the only place water is coming back up!! Is that possible it's just right there??
beginner50 is offline   Reply With Quote
Old 01-27-2013, 08:03 PM   #33
Plumber
TheEplumber's Avatar
Rewards Points: 350
It's sounds like its downstream from your tub, before the mainline tie in. The only fixtures backed up or effect the back up are secondary drains. I would cable from the kitchen - use a 3/8 cable long enough to get past the tub
Old 01-27-2013, 08:04 PM   #34
JOATMON
ddawg16's Avatar
Rewards Points: 818
I'm assuming you have a crawl space....I would suggest going down there and looking at the plumbing.....at least see how it is routed....it might help you figure out where the blockage might be.
But if your toilet is flushing ok....then the blockage is between the tub and toilet.
Your lucky....the overflow is going into your tub....and not your floor.
One last thing in case you haven't figured it out yet....tell everyone to stop using the sinks.....you want that water to drain down if at all possible....makes for less mess when you pull a cap off.
Old 01-27-2013, 08:05 PM   #35
Rewards Points: 22
It's possible, but it's coming up in the tub simply because that is your lowest drain.
Old 01-27-2013, 08:17 PM   #36
beginner50's Avatar
YEAH I FIGURED!!!! Well here is the pipes straight down from the tub!! Does that say anything or do nothing!!
Old 01-27-2013, 08:22 PM   #37
beginner50's Avatar
Better pic
Old 01-27-2013, 08:25 PM   #38
Plumber
Rewards Points: 350
your blockage is downstream from where the plastic ties into the cast iron
Old 01-27-2013, 11:33 PM   #39
beginner50's Avatar
Ok well finally got it!! Took the back off the wall took off the top drain stuck the snake down went all 15' pull it back out felt like I went through at a few spots but $15 is better than whatever a plumber was charging!! Thanks for all the info guys!!!
Old 01-27-2013, 11:58 PM   #40
Rewards Points: 12,830
Is it just me or does that line from the trap to the cast look like it's running up hill?
Also should there have been a clean out in there some place?
Old 01-28-2013, 02:04 AM   #41
747
registered
747's Avatar
Rewards Points: 534
Looks like its pitching to me toward the trap. From the big rubber boot going right. Thats no good
747 is offline   Reply With Quote
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 08:03 PM
Alcove bathtub but I want tile on the front wannabe gardner Tiling, ceramics, marble 1 09-13-2011 07:52 PM
Bathtub Waste Exit Relocation nixplix Plumbing 1 04-29-2011 08:45 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
