Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 01:31 PM   #1
beginner50's Avatar
Bathtub
I don't know what happened came into the bathroom and my bathtub is full of black nasty water!! Nothing else is doing it and basement isn't flooding or anything!!! Have been running washer since this morning!!! Need help!!!
beginner50 is offline   Reply With Quote
Old 01-27-2013, 01:42 PM   #2
beginner50's Avatar
Ok it's the garbage disposal but idk how to fix it!!!
Old 01-27-2013, 02:59 PM   #3
Rewards Points: 12,802
Whats a garbage disposal got to do with the tub drain backing up?
Could be one of many things, plugged up main sewer line, septic tanks full, leach field has failed, if there's a sump pit that pumps out the sewer it's not working.
Old 01-27-2013, 03:01 PM   #4
beginner50's Avatar
Well I say the disposal because it is the only thing that when turned on the tub bubbles and gets stir it up!!
Old 01-27-2013, 03:04 PM   #5
the Musigician
DangerMouse's Avatar
Smell the water, does it smell like your laundry soap?
DM
Old 01-27-2013, 03:08 PM   #6
beginner50's Avatar
DM
No it smells like the sewer water and has food that was put in the disposal!
Old 01-27-2013, 03:12 PM   #7
All that means is the line is backed up enough to also back up into the sink.
Having a garbage disposal is one way to get to know your plumber on a first name basis or have the joy of snaking sewer filled lines.
There againt the law around here.
Old 01-27-2013, 03:18 PM   #8
beginner50's Avatar
Well not really sewer water but our laundry soap is tide ( blue ) and its kind of blueish!!! How much is a plumber gonna cost any ideas???
Old 01-27-2013, 03:18 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 348
Not knowing your plumbing layout- I'd say your tub shares a line with the sink and it needs to be cabled- or your mainline is blocked. Do you have a floor drain on the same floor? Hows the toilet?
Old 01-27-2013, 03:24 PM   #10
beginner50's Avatar
Toilet is fine it's just the bathtub!!
Old 01-27-2013, 03:30 PM   #11
Plumber
Rewards Points: 348
Based on the little info you give- I'd cable from the kitchen sink with a 3/8 cable long enough to go past the tub- sounds like the blockage is downstream of the tub. You can rent one from a rental center for about 50 a day. Or pay a plumber about double that- or a little more.....
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
DangerMouse (01-27-2013), del schisler (01-27-2013)
Old 01-27-2013, 03:39 PM   #12
beginner50's Avatar
What other info would you like?? Both toilets are fine, upstairs bathroom is fine, kitchen sink is fine.
Old 01-27-2013, 03:49 PM   #13
beginner50's Avatar
Well now the sinks are both coming out into the bathtub!! The kitchen and bathroom sinks are draining into the bathtub!!
Old 01-27-2013, 03:52 PM   #14
It's got to go someplace if the lines pluged up.
Might want to call a plumber if this has you so confused.
Cheaper to call now before after hours rates kick in.
Old 01-27-2013, 03:54 PM   #15
beginner50's Avatar
Not confused it wasn't doing that before!!! Kinda why I'm on here for advice not to be treated like I'm stupid!!
The Following User Says Thank You to beginner50 For This Useful Post:
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 08:03 PM
Alcove bathtub but I want tile on the front wannabe gardner Tiling, ceramics, marble 1 09-13-2011 07:52 PM
Bathtub Waste Exit Relocation nixplix Plumbing 1 04-29-2011 08:45 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
