-   -   Bathtub (http://www.diychatroom.com/f7/bathtub-170275/)
beginner50 01-27-2013 12:31 PM
Bathtub
1 Attachment(s)
I don't know what happened came into the bathroom and my bathtub is full of black nasty water!! Nothing else is doing it and basement isn't flooding or anything!!! Have been running washer since this morning!!! Need help!!!
beginner50 01-27-2013 12:42 PM
Ok it's the garbage disposal but idk how to fix it!!!
joecaption 01-27-2013 01:59 PM
Whats a garbage disposal got to do with the tub drain backing up?
Could be one of many things, plugged up main sewer line, septic tanks full, leach field has failed, if there's a sump pit that pumps out the sewer it's not working.
beginner50 01-27-2013 02:01 PM
Well I say the disposal because it is the only thing that when turned on the tub bubbles and gets stir it up!!
DangerMouse 01-27-2013 02:04 PM
Smell the water, does it smell like your laundry soap?
DM
beginner50 01-27-2013 02:08 PM
DM
No it smells like the sewer water and has food that was put in the disposal!
joecaption 01-27-2013 02:12 PM
All that means is the line is backed up enough to also back up into the sink.
Having a garbage disposal is one way to get to know your plumber on a first name basis or have the joy of snaking sewer filled lines.
There againt the law around here.
beginner50 01-27-2013 02:18 PM
Well not really sewer water but our laundry soap is tide ( blue ) and its kind of blueish!!! How much is a plumber gonna cost any ideas???
TheEplumber 01-27-2013 02:18 PM
199 Attachment(s)
Not knowing your plumbing layout- I'd say your tub shares a line with the sink and it needs to be cabled- or your mainline is blocked. Do you have a floor drain on the same floor? Hows the toilet?
beginner50 01-27-2013 02:24 PM
Toilet is fine it's just the bathtub!!
TheEplumber 01-27-2013 02:30 PM
199 Attachment(s)
Based on the little info you give- I'd cable from the kitchen sink with a 3/8 cable long enough to go past the tub- sounds like the blockage is downstream of the tub. You can rent one from a rental center for about 50 a day. Or pay a plumber about double that- or a little more.....
beginner50 01-27-2013 02:39 PM
What other info would you like?? Both toilets are fine, upstairs bathroom is fine, kitchen sink is fine.
beginner50 01-27-2013 02:49 PM
Well now the sinks are both coming out into the bathtub!! The kitchen and bathroom sinks are draining into the bathtub!!
joecaption 01-27-2013 02:52 PM
It's got to go someplace if the lines pluged up.
Might want to call a plumber if this has you so confused.
Cheaper to call now before after hours rates kick in.
beginner50 01-27-2013 02:54 PM
Not confused it wasn't doing that before!!! Kinda why I'm on here for advice not to be treated like I'm stupid!!
