Bathrub Drain Question And Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2009, 03:47 PM   #1
Rewards Points: 49
bathrub drain question and problem
I re-did the plumbing run for an upstairs bath, tub to sing to toilet to stack. The length of pvc from the tub to the stack is about 4'. From the top of the trap to the stack there is adequate slope but I had to snake the trap and drain around a joist and so the bottom of the trap and the 3" of angled pvc are below the highest point of the slope. Will this adequately drain the tub? Does it sound problematic? Thank you!
jrdamien is offline   Reply With Quote
Old 07-31-2009, 06:31 PM   #2
are you saying you are back pitched ?
metx is offline   Reply With Quote
Old 07-31-2009, 10:38 PM   #3
Rewards Points: 49
I don't know what that means, but it sounds like what I am describing, so yes. Bad, good?
Old 08-04-2009, 05:49 PM   #4
is the pipe 3 inch? and does this section only service the tube?
ropers is offline   Reply With Quote
Old 08-04-2009, 10:20 PM   #5
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
pitch problem
The pipng has to go down never back up. So if it go's back up you will aways have a problem draining.
lonsplumbing is offline   Reply With Quote
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 09:46 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Problem with tub drain lineup dotwell Plumbing 2 10-21-2007 08:58 AM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 06:16 PM
