Bathroon Drain Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2009, 04:31 AM   #1
Joe F's Avatar
Rewards Points: 294
Bathroon drain rough-in
I'm roughing in a drain for a bathroom sink. What height off the floor should the stub come out of the wall?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 08-13-2009, 05:59 AM   #2
it depends on how high you want the lavaratory. short people 18". tall folks go 20" if you are going to go to a store and buy a pre-built unit then do so and dry fit it and see for yourself. if it is a wall hung lav use the 18-20 range. thanks, bb
buddy builder is offline   Reply With Quote
Old 05-31-2010, 07:41 PM   #3
about half a meter should be in the ballpark. It really doesn't have to be a certain height.
Charlie.Liu is offline   Reply With Quote
Old 05-31-2010, 10:59 PM   #4
I do 20"
SuperPlumberGuy is offline   Reply With Quote
Old 06-01-2010, 01:58 PM   #5
Rewards Points: 150
The measurments come with the sinks, if you don't want to use them keep your lines low and they will work; too high and you are SOL!
braindead is offline   Reply With Quote
Old 06-01-2010, 05:30 PM   #6
DIY staff
Rewards Points: 7,174
18" for drains
21" for waterlines. Standard height.
Those 'mixing bowl' sinks need a much higher drain---I don't know the standard for those.--Mike--
Old 06-03-2010, 08:31 AM   #7
Don't forget that your basement drains must be vented. Vent can be tied into the existing stack but where it connects to the existing stack must be 42" above the highest fixture on that stack. If it is a 2 story you must tie in above the second floor sink (42" above the floor). No vent is what most home inspectors find right off when you try to sell your house.
Nailer is offline   Reply With Quote
Old 06-03-2010, 12:05 PM   #8
Rewards Points: 352
I shoot for 161/2 in above finished floor
plumberinlaw is offline   Reply With Quote
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
