Bathroom Venting/Waste Design Outline - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-01-2011, 06:06 PM   #1
AJA
Bathroom Venting/Waste design outline
I am re-designing a bathroom and by extension the plumbing has fallen into my hands. But I have come across several questions and I am getting too many "that won't be a problem" type responses.
My main aim was to use direct venting rather then add additional venting pipes since the distances seem to adhere to code based on pipe size. I was planing on running a 3" pipe from bathtub so that distances are within code.
I can either run them separately to the main stack at different heights, or connect them to the same horizontal branch.
Can I connect two drains (bathtub/toilet) to the same vertical waste/vent stack at different heights? If so, does it matter which one is on top?
or can
Can I connect both bathtub and toilet to same horizontal branch that would lead into the vertical waste/vent stack, without an independent vent in between or before? In other words use direct venting for both running on the same branch.
I have found variations but generally I can run at least 8' vertically without a vent for a 3" pipe.
Thanks for the advice.
Bathroom Venting/Waste design outline-diagram.jpg
AJA is offline   Reply With Quote
Old 12-02-2011, 12:11 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Can you tell us what plumbing code you are referencing and where you live? Most of your description wouldn't fly in my neck of the woods
Old 12-02-2011, 02:38 PM   #3
AJA
Code and Location
The property is located in Saint Peters Missouri.
IRC 3105.1 Maximum Distance of Fixture from Trap Vent
For 2" size trap it gives a distance of 8 feet.
Tags
venting
Browse New Generation Bathrooms Design & styles bathroomsuk Plumbing 0 09-20-2010 02:38 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Planning for a bathroom rebuild ajtool Kitchen & Bath Remodeling 0 06-03-2010 10:47 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
