-   -   Bathroom Venting/Waste design outline (http://www.diychatroom.com/f7/bathroom-venting-waste-design-outline-125261/)
AJA 12-01-2011 06:06 PM
1 Attachment(s)
I am re-designing a bathroom and by extension the plumbing has fallen into my hands. But I have come across several questions and I am getting too many "that won't be a problem" type responses.
My main aim was to use direct venting rather then add additional venting pipes since the distances seem to adhere to code based on pipe size. I was planing on running a 3" pipe from bathtub so that distances are within code.
I can either run them separately to the main stack at different heights, or connect them to the same horizontal branch.
Can I connect two drains (bathtub/toilet) to the same vertical waste/vent stack at different heights? If so, does it matter which one is on top?
or can
Can I connect both bathtub and toilet to same horizontal branch that would lead into the vertical waste/vent stack, without an independent vent in between or before? In other words use direct venting for both running on the same branch.
I have found variations but generally I can run at least 8' vertically without a vent for a 3" pipe.
Thanks for the advice.
TheEplumber 12-02-2011 12:11 AM
199 Attachment(s)
Can you tell us what plumbing code you are referencing and where you live? Most of your description wouldn't fly in my neck of the woods
AJA 12-02-2011 02:38 PM
Code and Location
The property is located in Saint Peters Missouri.
IRC 3105.1 Maximum Distance of Fixture from Trap Vent
For 2" size trap it gives a distance of 8 feet.
