Bathroom Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 07:08 AM   #1
Bathroom venting
I'm in Ontario, Canada and totaly redoing the bathroom. Can a toilet, tub and sink be vented with 1.5"ABS, changing to 3" before it goes through the roofline?
djgap is offline   Reply With Quote
Old 05-12-2012, 08:57 AM   #2
with the limited info you have told us, i believe the answer is yes. check out this site, the fellow is in london, ON and it has really helped me.... http://www.3dplumbing.net/ontplumbing/
take what i say with a grain of salt, i am no pro
jsvelte is offline   Reply With Quote
Old 05-12-2012, 12:41 PM   #3
it's a bungalow, only one bath in the house, the kitchen sink will be vented independantly, but the kitchen drain (1.5") connects to the tub drain where it changes to 2" then the bath sink (1.5") connects to the 2" before it connects to the vertical 3". The toilet connects to the top of the 3" stack. The 3" stack changes to 4" cast iron before it goes through the basement floor.
I want to vent each fixture with a 1.5" vent and connect together into 1 - 1.5" pipe going into the attic then change to 3" going through the roof, rather than run 3" all the way up.
Bathroom Fan Venting Question elliotriley Roofing/Siding 5 03-26-2012 08:23 PM
ideas of venting a bathroom fan in attic david szela Building & Construction 10 01-14-2012 06:06 AM
Bathroom Fan Venting PeteW HVAC 17 09-05-2011 09:12 AM
Bathroom Remodel Venting JPWMU Plumbing 0 05-16-2011 08:23 AM
3rd Floor Bathroom Not Venting FEDERAL GOON Plumbing 4 06-15-2008 07:35 AM
