Old 04-19-2007, 12:04 PM   #1
bathroom tub and sink semi-clogged
hello,
the tub/shower and sink in one of our bathrooms is semi-clogged. the water in both drains real sloooow! we have tried plunging, and liquid plumber, helps, but not a fix. i pulled the trap off the sink to have a look, it was clean. the trap is brass/crome platted and goes into what looks to be 1 1/2" - 2" pvc. if i need to rent a snake, is there a special type of snake to use for pvc? should a 1/4" snake surfice? how would i snake the tub? from the overflow? the overflow also has the open/close drain control in it...bob P.S. the sink in the other bathroom drains fine, so it must be clogged between this bathroom and the main sewer line, correct?
bobo is offline   Reply With Quote
Old 04-19-2007, 12:19 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
As for plunging. You need to make sure any connected fixtures are blocked off so the plunging can work.
You may also have a clogged vent pipe.
Yes, you can snake from the tub overflow.
Brik is offline   Reply With Quote
Old 04-19-2007, 12:24 PM   #3
Did you block the over flows when plunging ? if not your just sucking air,If you need to rod out the tub the overflow is fine and on the lav you'll need to pull the trap and rod that way.
tzzzz216 is offline   Reply With Quote
