Bathroom Tub Diverter Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2009, 12:09 PM   #1
I need to replace the diverter spout on my tub.
I have removed the old one, but it looks like the original plumber left the copper pipe extended beyond what the spout requires.
The new spout that I've purchased has a mechanism on the inside of it that the old one doesn't, however, I can't seem to remove it. If It was not in there, the spout would be identical to the old one. That's what I need...Can anyone tell me how to remove the insides of this new spout?
karenmc is offline   Reply With Quote
Old 07-24-2009, 01:24 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Diverter spouts are made for different installations. The old one would have been either one that screws onto a specific length pipe with a male threaded fitting on the end of the pipe, or it would slide onto a straight pipe and seal with a rubber ring and be held in place with a set screw from underneath.
The new diverter that you have sounds like a universal diverter. You will probably tear it up trying to remove anything.
What does the pipe look like coming out of the wall? Straight? Threaded fitting on the end?
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-24-2009, 01:31 PM   #3
The copper pipe coming out of the wall is a straight copper pipe, male threaded on the end.
I think the plumber put the wrong spout on originally. The spout I am trying to replace simply screwed on to the copper pipe...but it has the place for the hex screw in it. I think it may have been modified.
Old 07-24-2009, 03:23 PM   #4
Long-Time DIYer
Measure the length of the pipe and male fitting from the wall, and get the proper type of diverter spout to fit it.
Good Luck!
Mike
bathtub diverter spout LCarlisle Plumbing 5 05-21-2009 08:18 AM
diverter spout gellsworth Plumbing 1 05-19-2009 08:15 PM
Tub spout diverter problem Chaosdragon13 Plumbing 2 05-28-2008 12:23 PM
Bathtub tub spout Diverter broken? tripower Plumbing 5 06-24-2007 06:44 PM
Teflon tape adequate for spout diverter? darsunt Plumbing 1 06-05-2007 01:50 AM
