Bathroom Tile Around Around Old Flange On Subfloor - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2011, 06:02 PM   #1
Bathroom tile around around old flange on subfloor
I have pulled up the linoleum floor in a small bathroom and plan to lay down tile. The subfloor is 3/4" plywood, and I intend to lay down 1/2" backer board and tile over that with 3/8" tile. The cast iron toilet flange is screwed on flush to the plywood subfloor. Can I leave it in place, and place the backer board and tile around it, and use extension and/or thick wax ring? Given that the flange is 1/4" thick, the finished tile floor would lie 1" above the height of the flange (if my thinset estimations are correct...
1)Are my estimations for thinset correct?
2)Can I get away with 1/4" backer board? (this would help with threshold issues too, since I'll be 1 3/16" above the halway wood floors if I use the 1/2" backer...)
3)Is it OK to have the toilet flange 1" below the finished floor?
Tile: 3/8"
Thinset: 1/4" (?)
Backer: 1/2"
Thinset: 1/8" (?)
Subfloor: 3/4"
Stable subfloor=1.25" with 1/2 backer; and 1" with 1/4" backer...
Thank you!
Thunderbird_ESQ is offline   Reply With Quote
Old 09-25-2011, 06:13 PM   #2
DIY staff
Rewards Points: 7,174
Use 1/4" backer board set into a bed of thinset and nailed or screwed---
Flange extenders are available as well as jumbo extension wax rings.
Old 09-25-2011, 06:22 PM   #3
Thanks oh'mike-
I'm in CT, I updated it, thanks for the tip!
Old 09-25-2011, 06:50 PM   #4
DIY staff
Look through the tiling section here----lots of folks doing bath floors.
Here is one link that will help"Mud" What Is It? - Kitchen & Bath Remodeling - DIY Chatroom - DIY Home Improvement Forum
Tags
bathroom , tile , toilet
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Toilet Flange Problem - New Tile Floor w/ Ditra qwkslvr Flooring 4 10-14-2009 11:04 PM
replacing subfloor for tile upgrade bucaronco Flooring 5 07-29-2009 05:35 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 07:18 PM
Removing damaged bathroom subfloor icandoitmyself Flooring 3 10-23-2007 09:50 AM
