Bathroom Sink Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2012, 01:12 PM   #1
Bathroom sink venting
We have a sink in the bathroom that is slow to drain. This is an addition to the house and I can't find where the sink is vented. The attic above is not accesible so a roof vent is out. Is it possible to add a small vent line and go through the exterior wall and up the outside wall with a small vent line?
don6861 is offline   Reply With Quote
Old 01-05-2012, 05:24 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Yes, it is possible.
Will your jurisdiction allow you put an ugly pipe on the exterior wall?
Who knows.
Andy.
AndyGump is offline   Reply With Quote
Old 01-05-2012, 06:28 PM   #3
Rewards Points: 582
no sure where you live but i would consider installing auto vent under the sink would need a picture has the drain always been slow.... has it been snaked out...ben
Old 01-05-2012, 06:40 PM   #4
DIY staff
Rewards Points: 7,174
If it's a bathroom--there must be a vent for the toilet--Where is the sink in relation to the toilet?
Have you removed the P-trap to see if there is a T inside the wall?
Old 01-05-2012, 07:40 PM   #5
Rewards Points: 1,192
I was just going to ask if the v-200 vents wear out after 28 years. My game room sink has a septic smell only when I run water.
bobelectric is offline   Reply With Quote
Old 01-05-2012, 07:42 PM   #6
Rewards Points: 582
not that expensive change it you will find out ....but yes they do go bad...ben
Old 01-05-2012, 07:46 PM   #7
Thanks, Ben. I'll go get a new one.
Old 01-05-2012, 07:49 PM   #8
Rewards Points: 582
welcome
Old 01-06-2012, 08:42 AM   #9
sink vent
There is no toilet in this room, only a shower and sink. We live in the country so no zoning issues to consider plus there is a huge bush in front of the wall where I was thinking of adding the exterior vent. How do I get info on the under the sink vent?
Old 01-06-2012, 07:23 PM   #10
Rewards Points: 582
just ask any clerk in the plumbing dept at lowes,h.d..or hardware...they will give you what you need....if you can get us some pictures we can help you figure out howw to install under sink...ben
Old 01-06-2012, 08:24 PM   #11
DIY staff
It's called an AAV---air admittance valve--Google images will have a picture--
Old 01-07-2012, 09:24 AM   #12
problem update - still at a loss
After trying several things, I gave up and hired a plumber. We installed an under sink vent, snaked the lines out to the septic tank, replaced all the undersink drain lines and $450 later, the problem is still there. It appears to have something to do with the pop up stopper. When the stopper is completely removed, the drain works great. When the stopper is there, even with a half inch between the rubber o ring on the bottom and the top of the seat, it still backs up the running water. I even cut two of the 4 guide vanes off, thinking they were restricting, no affect. This is a 2 year old one piece sink and counter top. Does the overflow vent have anything to do with getting air behind the draining water? Could it be stopped up or restricted somehow? So far my best solution seems to be a rubber stopper and chain!!!
Old 01-07-2012, 09:38 AM   #13
MarginallyQualified
Rewards Points: 2,464
...one piece sink and counter top.
It really shouldn't...
Stopper the sink to overflow level and see if it goes down easier.
The pipe coming out of the wall... how much lower than the sink drain is it?
Have you opened that wall yet to see how the dwv is set up?
Old 01-07-2012, 11:00 AM   #14
the drain pipe drops vertical through the floor about 24" directly into the 4" pipe leading to the septic tank
Old 01-07-2012, 06:01 PM   #15
DIY staff
I've read of that problem here----with those mixing bowl type sinks--(vessel) -
Solution,as I recall, was a different brand of pop up ---Rare--I bet the plumber felt pretty dumb--
(well paid,but dumb)
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 13 05-10-2016 10:01 AM
Kitchen sink venting issue erm213 Plumbing 9 05-24-2011 02:01 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Caulking around bathroom sink KarenRB53 Plumbing 2 09-17-2009 10:21 AM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 11:24 AM
