Bathroom Sink Valves Will Not Turn - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2015, 08:23 PM   #1
Rewards Points: 4
Bathroom sink valves will not turn
Hello
Just closed on a short sale home that was winterized. Im gutting 2 of the bathrooms and for the life of me I cannot turn either of the hot or cold valves under the sink. Strange thing is these valves are in the on position (water flows into the sink). I took a pair of channel lock and cranked on them a bit, but before I go and turn off the water to the house and remove the valves was hoping someone might have an idea. Valve appear to be standard with the t-like handle. Thanks!
Cologuy is offline   Reply With Quote
Old 04-21-2015, 08:55 PM   #2
Rewards Points: 13,446
If your gutting them then you should be removing the valves anyway and capping the lines so you can remove and install the new sheet rock.
No way would I remodel any bath or kitchen and not install new stops.
Old 04-21-2015, 08:56 PM   #3
Sounds like they seized up or someone soldered them right to the pipe.
Try some pb blaster or wd 40 let it soak for awhile , give it few taps, and try again. Try both directions you may be able to free them. Look for another possible isolation valve. If no luck youll have to turn the house water off and replace them.
Others will be along with more suggestions. Eplumber or bens plumbing probaly will know a few tricks.
jmon is offline   Reply With Quote
Old 04-21-2015, 08:59 PM   #4
Rewards Points: 980
Try temporarily loosening the bonnet nut just a little.
Old 04-21-2015, 11:06 PM   #5
Rewards Points: 2,906
By that do you mean that the valves are Brasscraft stops similar to these:
If so, you should be aware that you can order metal handles for these valves that might make opening and closing them more do-able.
Contact Brasscraft at 1-800-265-4322 and ask who you can order a pair of metal handles from in your area. Brasscraft's part number for their metal handles is R15-10T C. The C on the end means it's a Chrome plated metal handle as opposed to a plastic handle.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 04-21-2015, 11:41 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 546
Yep, they're seized. Best to replace them with new 1/4 turn shut offs.
Consider it part of any kitchen, bath remodel- new faucet, supplies and stops
Old 04-22-2015, 04:46 AM   #7
Rewards Points: 3,130
Excellent advice. The shutoff almost never get used, but when you need them, well, you need them to work.
Old 04-22-2015, 09:27 AM   #8
Rewards Points: 4
Thanks!
Great advice! I'll turn off the house water and replace them with 1/4 turn valves!
On to the next step!
The Following User Says Thank You to Cologuy For This Useful Post:
jmon (04-22-2015)
Old 04-23-2015, 11:06 PM   #9
Rewards Points: 136
I agree with replacing the valves, but fyi for all, if you have a stop (valve) similar to the one posted by nester, then keep in mind the stem sometimes seizes to the packing. Place a doubled up layer of paper towels or a good rag under the valve, loosen the packing nut, then try to turn the stem. It works for me 90% or the time and then retighten the packing nut after things get some moistur in them, and wallah!!, if no need to change the valve, no need to change the valve.
karin els is offline   Reply With Quote
Stuck on small bathroom sink supply lines (Going from ground up) mrrhtuner Plumbing 5 01-13-2015 06:15 PM
Turning off valves bathroom sink richard7994 Plumbing 3 11-28-2011 05:25 PM
bathroom sink stopper question - Pictures in thread amodoko Plumbing 5 05-31-2011 05:24 PM
add second bathroom sink - tap into original denemante Plumbing 1 03-22-2011 12:21 AM
bathroom sink drain line how small can I go? walt1122 Plumbing 3 07-02-2010 09:52 AM
