Bathroom Sink Supply Line Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-24-2010, 04:14 PM   #1
Bathroom sink supply line leak
Hi,
Novice diy-er here....A previous owner of my apartment connected a spray nozzle to my bathroom sink. It's attached at what I believe is the supply line. The hose was coiled under the sink and I didn't notice it for a while. Recently it started leaking. It looks like there's a hole drilled through the supply line where this hose is connected. There's a little screw or handle close to the supply line that seems to be the original "on/off" faucet.
How do I fix this? Do I need to be more specific? I can provide photos if that helps...
afarr
afarr is offline   Reply With Quote
Old 05-24-2010, 05:32 PM   #2
Pics would help
Old 05-26-2010, 08:26 AM   #3
Pics of how the hose is attached....
Here are a couple of pics...I really need to vacuum back there...sorry!
Bathroom sink supply line leak-photo-2-.jpg   Bathroom sink supply line leak-photo.jpg
Old 05-26-2010, 02:38 PM   #4
Rewards Points: 156
afarr,
First, shut off the water. It looks like if you cut the pipe before that ridiculous puncture valve (?), I don't know what it is, you will still have enough room to put a 90 degree compression fitting valve on the pipe. You can then hook up your water supply line to the valve and be done. This will require no soldiering and minimal skill.
Branden is offline   Reply With Quote
Old 05-26-2010, 04:18 PM   #5
Branden,
that's the best news i've heard all day...seriously!
and yes, that thing is ridiculous.
thanks so much,
afarr
Old 05-26-2010, 05:24 PM   #6
Rewards Points: 156
hey afarr, after you shut off the water I would take that piece of garbage off and cut as close to the hole as you can with a pipecutter, just to give you as much pipe as possible to work with.
Old 05-26-2010, 05:59 PM   #7
Leak Master
Whooo nelly, before you do any work, please clarify for me. You said the previous owner of your apartment. Does that mean someone else owns the place? If so, don't touch anything!!! If you own it then cut the saddle valve off and try your hand at what would be a simple repair for a professional.
Cut it off and get a 5/8 by 3/8 comp stop, and re-hook up supply line.
O'Leaky is offline   Reply With Quote
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 01:30 PM
Basement bathroom sink drain line on a slight upwards slope an issue? dtran Plumbing 7 01-10-2010 05:05 PM
How to Install a Water Line to a Refrigerator With No sink yerac2003 Plumbing 6 05-07-2009 03:27 PM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 08:11 AM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
