Old 11-13-2008, 04:41 PM   #1
Bathroom sink shut off valve
Hi there
I dicided to change the sink in my bath room. I bought a new one and changed it my self (first time doer )..... Everythin went well except after inserting the brass hot and cold pipes (coming out from the tap) into the shut off valve, water is oozing from the shut off valve. Do I have to use some tape or sealing compound before I insert these brass pipes or am I missing something? Please advice.
Thanks in advance
w11x22 is offline   Reply With Quote
Old 11-13-2008, 05:39 PM   #2
bradnailer's Avatar
If the water is seeping from the valve itself (like from around the stem), it's time to replace the valve. It is not uncommon to have an older shut off valve start leaking after it's closed and opened.
If it's seeping from the connection, then you can use teflon tape on the connection and possibly seal it.
bradnailer is offline   Reply With Quote
shut off valve under sink mathmama Plumbing 7 05-16-2010 06:27 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
What to plug sink, toilet lines with, No Shut off valve for house? twilightcall Plumbing 4 05-14-2008 03:02 PM
Toilet water Supply- Shut off valve kcreds Plumbing 5 04-07-2008 01:44 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 01:28 AM
