Bathroom Sink Rust Removal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2008, 01:16 AM   #1
bofusmosby's Avatar
bathroom sink rust removal?
I am installing an antique cast-iron sink in my bathroom, and for the most part, the original finish looks pretty good. There is some rust around the bottom of the bowl, but I believe I might be able to scrub that off. It looks to be a light/thin coating. However, there is one place where the rust is pretty thick, and that is around the over-flow vents. What would be the best way of removing this rust? I was planning on using some "marine tech epoxy" for filling the pitted surface around the vents. It dries high gloss white, and I have used it before for other things. My main problem is removing this "crust" of rust. Also, is there any chemical that is best for cleaning the surface rust? I figured I would ask.
Thank you for any advice you can give.
Bofus
bofusmosby is offline   Reply With Quote
Old 11-12-2008, 01:38 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You might try Iron Out, naval jelly, pumice stone, etc.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-12-2008, 07:30 AM   #3
bofusmosby's Avatar
Naval Jelly! Damn, I forgot all about that. I used to use that stuff on my bikes as a kid growing up. That stuff worked great. One question though, will it harm the finish? If not, I need to get some. Thanks for you input, and rattling my brain.
Old 11-12-2008, 08:00 AM   #4
Long-Time DIYer
I don't think that it will harm the finish, but I'm not certain. You might want to try just a little bit in a small spot at first.
Mike
Old 11-12-2008, 06:28 PM   #5
bofusmosby's Avatar
Thank you Mike for knocking me up-side the head. I can't believe I had forgotten that stuff. I remember it worked great! I will do as you suggest, try a little on the back-side of the sink. I'll let you know how it turns out.
Bofus
Double sink bathroom rough-in MikeyP Plumbing 2 09-30-2008 09:29 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
Clogged bathroom sink, help!! tripower Plumbing 22 11-13-2007 09:21 PM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 11:24 AM
