Bathroom Sink Leaking <--help Please - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2010, 02:59 AM   #1
Rewards Points: 31
Question
Bathroom Sink leaking <--help please
Hello -
I have a 3 year old house and we have a bathroom sink leaking. As you can see in the picture, it is coming between the sealant and the "black plastic thing" that looks like a mount of some sort.
It seems to only be leaking when the basin is filled up and then drained.
Any ideas how to fix this? Do I need a new sink; drain; "black plastic thing"?
Thanks for any help!
https://docs.google.com/leaf?id=0B9P...MTZkYTk1&hl=en
dgates12 is offline   Reply With Quote
Old 06-12-2010, 07:13 AM   #2
DIY staff
Rewards Points: 7,174
I vote for a new sink----That black channel is the over flow--Built into the sink----
The adhesive is failing--plastic may be distorted---
You could try sealing the channel with silicone caulk,as a 'quick fix'
But you will want to replace that sink.----Mike---
Old 06-12-2010, 10:09 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It looks like a plastic sink too.... amirite?
I'd vote to replace it with a china one that has the overflow built into it.
You can get cheap ones for 20-30 bucks.
Journeyman Plumber
Old 06-14-2010, 10:53 AM   #4
Leak
Are you sure it is not leaking from under the faucet and just running down the outside of the overflow channel? Try drying the whole underside of the sink, then tape a paper towel under the sink from the back to the drain. Turn on the water and watch to see where the leak starts.
Roy Rowlett is offline   Reply With Quote
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
bathroom sink pressure issue. tgamblin Plumbing 4 04-27-2009 01:21 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 10:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
