Bathroom Sink Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2008, 04:54 PM   #1
Rewards Points: 123
How are the holes for a faucet determined?
I see reference to 4" and 8" on center. How do I determine what mine are?
jerome8283 is offline   Reply With Quote
Old 03-15-2008, 04:59 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Measure center of hole to center of hole, if it's 4" then it's 4" center.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-15-2008, 07:38 PM   #3
I find it is easier to measure LH edge to LH edge or RH edge to RH edge rather than guess at center.
BillyD is offline   Reply With Quote
Old 03-15-2008, 08:17 PM   #4
Building and plumbing
USP45's Avatar
Rewards Points: 150
You are not trying to measure 1/16" here. It will either be 4" or 8" as Ron has said, so it is fairly easy to tell.
USP45 is offline   Reply With Quote
Old 03-15-2008, 09:31 PM   #5
Rewards Points: 123
That would be the two outer of the three holes correct?
Old 03-15-2008, 11:27 PM   #6
Journeyman Plumber
That's correct.
Old 03-16-2008, 08:35 AM   #7
Rewards Points: 123
That's correct.
Thanks Ron. The installer screwed up. I had a granite top cut for a vanity and the installer came by prior to measure. He saw the faucet I wanted to install and noted the measurement from the box which said, "compatible with 4" centers". Well, I picked up the granite top and notice right away that the holes appeared to far apart. After measuring, they are 8" on center.
I will take the faucet back today.
Thanks for your help!
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 05:08 PM
Clogged bathroom sink, help!! tripower Plumbing 22 11-13-2007 10:21 PM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 10:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
