Bathroom Sink Faucet Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2012, 05:06 PM   #1
bathroom sink faucet removal
I have a 25-30 yr old faucet, flex tubing disconnected, pop-up drain removed, faucet does not have plastic nuts to attach to sink, it has a big brass piece with a plate on the underside of the sink, can't get the spigot loose, got the handles loose but stems are still in place. Don't see an obvious nut on underside brass fitting anywhere.
BenScott is offline   Reply With Quote
Old 07-01-2012, 05:21 PM   #2
Renovations contractor
Bonzai's Avatar
There are literally 1000's of different faucets so need more info and preferably pics.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-01-2012, 06:45 PM   #3
DIY staff
Rewards Points: 7,174
If you have a three piece faucet--two handles and a spout---the handles are held in from the top side--
Remove the handles--unscrew the bell shaped cover--and you will find a nut holding on the valve---
oh'mike is online now   Reply With Quote
Faucet Leak below kitchen sink and from the Delta faucet: Replace or Repair? spyboy Plumbing 14 05-13-2014 07:03 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Shut off valves under bathroom sink EveB Plumbing 7 03-16-2011 12:28 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Loud noise, no hot water in bathroom sink loniac Plumbing 5 11-24-2010 11:52 AM
