-   -   bathroom sink faucet removal (http://www.diychatroom.com/f7/bathroom-sink-faucet-removal-148834/)
BenScott 07-01-2012 06:06 PM
I have a 25-30 yr old faucet, flex tubing disconnected, pop-up drain removed, faucet does not have plastic nuts to attach to sink, it has a big brass piece with a plate on the underside of the sink, can't get the spigot loose, got the handles loose but stems are still in place. Don't see an obvious nut on underside brass fitting anywhere.
Bonzai 07-01-2012 06:21 PM
There are literally 1000's of different faucets so need more info and preferably pics.
oh'mike 07-01-2012 07:45 PM
If you have a three piece faucet--two handles and a spout---the handles are held in from the top side--
Remove the handles--unscrew the bell shaped cover--and you will find a nut holding on the valve---
