Bathroom Sink Drain Repair Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2012, 05:51 AM   #16
DIY staff
Rewards Points: 7,174
That is not going to be fun----in order to unscrew that pipe,a chain wrench might save you from damaging the wall---
They can be rented---
You will need a new drain pop up---that one is missing the tail piece--
Definitely install the P-trap temporarily before adding the drain to make sure the P-trap will make the trap adapter properly,if you try for a centered drain.
Old 01-29-2012, 09:27 AM   #17
Rewards Points: 582
ok great picture easy to replace to stack....cut pipe.. unscrew from stack..clean hub... 1 1/2 pvc male adapter screw into stack hub ..pipe back to sink same way ....good to go...
Old 01-29-2012, 08:49 PM   #18
jasin is offline   Reply With Quote
Old 01-29-2012, 09:29 PM   #19
Rewards Points: 616
best thing is to cut galvanized pipe near cast put a shielded fernco run a peice of 1 1/2 pvc pipe prime and glue 90 and sink adapter inside hub add new 1 1/2 or 1 1/4 trap and new pop up whole thing should cost 40 dollars then if you ever need to change out cast iron it is easy to reconnect sink
jaydevries is offline   Reply With Quote
Old 01-30-2012, 07:18 PM   #20
Those shielded fernco are pretty solid. That is definitely a good way to go.
Old 01-30-2012, 07:29 PM   #21
He talked about using pvc. Cpvc is much better option though.
Old 01-30-2012, 07:47 PM   #22
Rewards Points: 582
hey jasin cpvc is for water lines....ben
Old 01-30-2012, 08:22 PM   #23
I see hot and cold lines too, in picture #4 & 5 on post #1.
The Following User Says Thank You to jasin For This Useful Post:
ben's plumbing (01-30-2012)
Old 01-30-2012, 08:43 PM   #24
So would it be better to use a rubber coupling on the steel after I cut it, or unscrew it from the cast iron?
mainstreeet is offline   Reply With Quote
Old 01-30-2012, 08:52 PM   #25
DIY staff
Either will work just fine---your choice---In a perfect world unscrew it and use a threaded fitting--but this is not a perfect world.
Old 01-30-2012, 08:57 PM   #26
That's If he can get it unscrewed.
Old 01-30-2012, 10:58 PM   #27
Rewards Points: 582
try to unscrew it 1st ....that would be better... if it won't come out go to fernco....ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (01-31-2012)
Old 02-03-2012, 12:57 PM   #28
Just started working on replacing my drain today. I cut the steel pipe and I think I might of found what was causing the slow drain. Haha
Old 02-03-2012, 01:09 PM   #29
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Yeah thats more common than most people think
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-04-2012, 02:43 PM   #30
All installed waiting for the glue to dry.
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 13 05-10-2016 11:01 AM
Old Crain Connection for Bathroom Sink Drain dhcox36 Plumbing 2 01-11-2012 11:01 PM
PVC sink drain pipe... Ed911 Plumbing 4 12-01-2011 11:09 AM
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 02:39 AM
2nd story bathroom, drain &vent, please help!!! serik Plumbing 4 07-15-2009 08:33 AM
