Bathroom sink drain pipe on the side of the wall
23K views 7 replies 4 participants last post by  amandanory
#1 · (Edited)
I am replacing a bathroom sink with cabinet. The only issue which is major is that the drainage from the sink pluming is coming thru the right wall and has a elbow that would cause me to have to make a huge hole in the cabinet to make it fit. I have thought about a couple other options like cutting the elbow from the pipes and just put a new elbow after i put the cabinet so i can just make a normal hole in the cabinet. Not sure how i would be able to fit the pipes directly onto the sink drainage and how that would align after i cut the pipe and have to re do the pipping.
Sorry about the pic, for some reason it will not switch from side posting. That panel there is from the old cabinet, that is going to be removed and i will be putting my new cabinet in.
i am trying it to be as small of a project as possible, the picture is under my post. I cannot re route the plumbing under the house because the floor is my ceiling for the downstairs floor and my other bathroom for the top floor share a wall with this bathroom that is the reason why the plumbing is coming thru the wall
#4 ·
I would have just cut that pipe in the middle of the straight section, used a hole saw to make the hole big enough for the pipe to fit in the side of the cabinet, mount the cabinet and used an ABS coupling to reconnect everything. There was no reason to take the cabinet apart like it looks like you may have.
Even if you needed to remove the toilet to get the cabinet in place. A $2.00 wax ring is all it would have cost.
Reactions: amandanory
#6 ·
You'll have to cut off the "elbow" anyway - there's almost zero chance that the new sink drain is going to line up with the old trap. It will have to reconfigured anyway, so just cut it off. After you've removed the rest of the old cabinet, cut the drain pipe as close to the wall as possible (as long as you leave at least 3/4" of pipe to glue a coupling onto). Drill an oversized hole (2 1/2") in the side of the new cabinet so that you can reach the glue dawber in and fit the coupling on after the cabinet has been installed. The handles on the hot and cold shut-off valves can be removed with a screwdriver so that you can fit the new cabinet a little more easily also
