Bathroom Sink Drain Min. Drain Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-15-2012, 09:51 AM   #1
Rewards Points: 77
Bathroom sink drain min. drain size
Hello,
What would be the minimum abs drain line I could use for a basement bathroom sink? The run is approx 4-5' to the main stack. I am thinking 1-1/4". Thanks!
mlijoi is offline   Reply With Quote
Old 11-15-2012, 11:34 AM   #2
Rewards Points: 3,130
I believe that is correct.
Old 11-15-2012, 11:48 AM   #3
Rewards Points: 352
that would be ok if it is 4' any longer requires larger pipe. Drainage has to be set for 1/4" pr foot.
plumberinlaw is offline   Reply With Quote
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 13 05-10-2016 11:01 AM
minimum drain size for tub/shower and for sink Arky217 Plumbing 3 10-05-2012 11:10 AM
2 3/8 Drain hole in bathroom sink... travdes Plumbing 1 08-26-2012 12:26 AM
Old Crain Connection for Bathroom Sink Drain dhcox36 Plumbing 2 01-11-2012 11:01 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
