Bathroom sink drain min. drain size
Hello,
What would be the minimum abs drain line I could use for a basement bathroom sink? The run is approx 4-5' to the main stack. I am thinking 1-1/4". Thanks! |
I believe that is correct.
that would be ok if it is 4' any longer requires larger pipe. Drainage has to be set for 1/4" pr foot.
| All times are GMT -4. The time now is 04:53 AM. |
