Old 11-17-2007, 06:01 PM   #1
Bathroom sink drain leakage
Can't seem to get the gasket to seat fully on bottom of sink where drain is. Can't tighten it any tighter else I'll break the plastic. I s there any kind of material or "goo" I can put in there to seal it?
RickB is offline   Reply With Quote
Old 11-17-2007, 11:15 PM   #2
Send a message via Yahoo to fburke
use a bead of plumbers putty or some clear silcone
fburke is offline   Reply With Quote
Old 11-18-2007, 12:02 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
If you use clear silicone caulk, you can use Goo Gone citrus-based adhesive solvent to clean it up with.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-18-2007, 02:50 AM   #4
Yes, plumber's putty is generally used despite whatever type of gasket that comes with the drain. Roll a thin bead like if you were making a breadstick, and then just wrap it around the drain before you tighten it. After you tighten it, the excess will just be squeezed out. Plumber's putty is easy to clean w/o chemicals.
handy man88 is offline   Reply With Quote
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
Clogged bathroom sink, help!! tripower Plumbing 22 11-13-2007 10:21 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
