-   -   Bathroom sink drain leakage (http://www.diychatroom.com/f7/bathroom-sink-drain-leakage-13510/)
RickB 11-17-2007 05:01 PM
Can't seem to get the gasket to seat fully on bottom of sink where drain is. Can't tighten it any tighter else I'll break the plastic. I s there any kind of material or "goo" I can put in there to seal it?
fburke 11-17-2007 10:15 PM
use a bead of plumbers putty or some clear silcone
Mike Swearingen 11-17-2007 11:02 PM
If you use clear silicone caulk, you can use Goo Gone citrus-based adhesive solvent to clean it up with.
Mike
handy man88 11-18-2007 01:50 AM
Yes, plumber's putty is generally used despite whatever type of gasket that comes with the drain. Roll a thin bead like if you were making a breadstick, and then just wrap it around the drain before you tighten it. After you tighten it, the excess will just be squeezed out. Plumber's putty is easy to clean w/o chemicals.
