Bathroom Sink Drain Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2009, 06:10 PM   #1
bathroom sink drain connection
I had a friend help connect a new sink/cabinet and the drain did not align. He cut the floor drain shorter and connected to pvc connections. Every connection leaks. I got a flex fitting but now can't figure out how to align the fittings to avoid leaks.
wdrwmn is offline   Reply With Quote
Old 03-01-2009, 06:41 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Sorry but I'm not following you at all. Are you draining this into a floor drain??? Posting a picture will help everyone get a clearer idea of what you've got going on.
JDC is offline   Reply With Quote
Old 03-01-2009, 09:24 PM   #3
A floor drain 1 1/4" pipe in concrete. What will connect to cut pipe without leaking?
Old 03-14-2009, 04:39 PM   #4
Send a message via AIM to rh8868 Send a message via MSN to rh8868
Fernco
What about a flexible coupling? They are a rubber fittings with a clamp on each end to connect two ends of plumbing. Be careful of the types of pipes your connecting though, some may not be recommended for these types of products. I know they work fine for PVC though. Most the big box stores have them in generic sizes, by Fernco or American Valve.
http://www.fernco.com/plumbing/flexi...tock-couplings
rh8868 is offline   Reply With Quote
Bathroom Sink Drain (Broken from wall to Ground) bli182nk Plumbing 2 01-11-2009 07:52 PM
Bathroom sink drain extension Docfletcher Plumbing 2 12-10-2008 10:30 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 11:28 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
