Bathroom Sink Drain (Broken From Wall To Ground) - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2009, 03:13 AM   #1
Bathroom Sink Drain (Broken from wall to Ground)
There was a clog in the drain so I took off the connections under the sink to unclog. When I went to attach back to the water drain the pipe broke, the pipe from the wall to the ground)... I cut the sheet rock to get to the pipe to see what I was dealing with I cannot find where the drain pipe went into the ground. I looked and looked. The obvious answer is straight down... I thought I was going crazy but I cannot find where the spot where the pipe broke..
I had purchased flexible couplings to reconnect the drain pipe but without seeing where the pipe broke I cannot fix. THe foundation is cement but the water supply lines that all come from the ground so the drain pipe would too, right? I am hoping someone can give me some insight here.. Thanks.
bli182nk is offline   Reply With Quote
Old 01-11-2009, 08:35 AM   #2
Can you get a couple of pictures so we can see what you're talking about?
Handy1 is offline   Reply With Quote
Old 01-11-2009, 07:52 PM   #3
Sure.. I live in Dallas this happened at my Grandpa's house... I am going back tonight. I am not sure if the pictures would help. But I am sure you would know a lot more than me when you saw the pics.. I will try to get them on tonight or tomorrow..
Sink Drain LaMarguerite Plumbing 2 10-22-2008 04:26 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 10:56 AM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 06:42 PM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 09:17 PM
sink drain Ben kiemele Plumbing 1 03-15-2005 06:03 AM
