#1 |
Bathroom sink clogged
I just tried to clear a slow bathroom sink drain and now it is totally blocked. The shower and toilet are fine but the bathroom sink is now backed up solid. I used a crystal drain cleaner and after running water thru I used a plunger, then the back up came and itthe sink filled up with what looks like muddy water.
I have snake that i want to use but I thought I'd get some advise first, any help would be appreciated. Thanks John P |
#2 |
Wearing rubber gloves and eye protection (since you already used a caustic drain cleaner), remove the trap and clean it out. Then run the snake down the piping.
If you have never made a mistake, you haven't done much. |
#3 |
I will give that a try, Thanks for yuor help
| Display Modes | |
| Bathroom sink is clogged. | Karmapedler | Plumbing | 8 | 09-10-2010 10:00 PM |
| Remove bathroom sink from cabinet stuck with silicone | Bucker | Plumbing | 5 | 09-10-2010 03:15 PM |
| Installing bathroom sink - drains off slightly less than pipe diameter | lazzlazz | Plumbing | 17 | 05-21-2010 06:12 PM |
| Need advice on changing from one sink to two in bathroom | cari | Off Topic | 1 | 04-17-2010 07:23 AM |
| Scratch on bathroom sink/mold on sink | sbaulch | General Discussion | 4 | 02-16-2010 09:53 PM |
