Bathroom Sink Aerator Causing White Water? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 02:00 PM   #1
Bathroom sink aerator causing white water?
Not sure why my bathroom sink aerator is all of a sudden turning the water white, but it seems to be only when the water is on all the way. My main question though, is could it just be because the pipes have been cold & the heater running recently, and if that's the case would it be likely to clear up on its own as the weather warms up? Several internet sources indicated that cold pipes tended to cause this issue, but nothing said whether it then went away by itself. Thanks for any info!
smartypants47 is offline   Reply With Quote
Old 02-24-2013, 02:41 PM   #2
Water Treatment
Rewards Points: 816
If you put that water into a glass and let it set for a minute or so that air would come out, it is the air that is making the water white.
Akpsdvan is offline   Reply With Quote
Old 02-24-2013, 02:59 PM   #3
Thanks for the help! I realize that the water is fine to use, just wanted to know if anyone knows for sure if it's affected by temperature/weather.
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-25-2012 12:23 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Wierd problem with non-draining bathroom sink Wife Plumbing 3 02-26-2011 07:25 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
