Bathroom Sink Aerator - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2013, 01:38 PM   #1
Hi,
Our bathroom sink needs a new aerator. However, the aerator is frozen solid. I have tried using calcium and lime remover, which removed some of the calcium build up, but didn't loosen it. I've also tried WD40 and pliers, neither of which worked.
Yes, I'm turning the correct direction of counter clockwise.
Does anyone have a suggestion on how to get it loose? I'd rather not have to replace the whole faucet.
Thanks in Advance.
skyvalley4jesus is offline   Reply With Quote
Old 05-04-2013, 02:14 PM   #2
Roofmaster
Rewards Points: 2,210
Well, there is your problem. Put a pair of channel locks on it and turn clockwise looking down. CCW on something screwed up at you tightens it.
Old 05-05-2013, 11:56 PM   #3
Worked. Thanks for the tip. Seem another couple of turns got it loose. Cleaned out, put back together and good as new.
Tags
aerator , bathroom , sink
Help with Bathroom Sink Supply Line RudySands Plumbing 3 02-07-2013 07:46 PM
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 01:13 PM
How to Remove Porcelain Bathroom Sink from Tile Countertop llander Kitchen & Bath Remodeling 1 11-27-2012 11:31 AM
Inset aerator on a bathroom sink macklaws1 Plumbing 4 06-07-2011 08:14 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
