Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2012, 09:47 PM   #1
bathroom sink
the trap in my bathroom sink is not flush
dallas10 is offline   Reply With Quote
Old 01-05-2012, 10:00 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
A little more info please
Old 01-05-2012, 10:01 PM   #3
Rewards Points: 582
get us a picture if you can....would help
Old 01-05-2012, 10:08 PM   #4
Rewards Points: 13,722
Flush with what?
Old 01-05-2012, 10:10 PM   #5
i installed a new faucet in bathroom sink. when i screwed water trap in, it left a gap in sink where water drains. i caulked around trap, but it looks like water might sit around caulk.
Old 01-05-2012, 10:27 PM   #6
If you mean the sink bowl to the drain, it's not tight enough.
There should not be a needs for any caulking.
You did use the flat rubber washer under the lip of the drain, right?
Old 01-05-2012, 10:36 PM   #7
i do have a clear plastic washer that i didn't know what to do with, could that be it.
Old 01-05-2012, 10:43 PM   #8
Have you looked at the directions?
I've never seen a plastic one except one that was suppost to go between the nut on the bottom and the big tapered sealing ring ounder the sink.
It acts as a slip ring so the seal ring does not try to turn as you tighten it.
If there is no washer then plumbers puddy is used under the lip. Not on top of it or around it.
dallas10 (01-05-2012)
Old 01-05-2012, 10:53 PM   #9
i dont see any other washer, and yes that plastic piece did come from underneath. i'll put it back on and will get some plumbers putty. thanx joecaption you've been a big help !!!
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 06:41 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
Caulking around bathroom sink KarenRB53 Plumbing 2 09-17-2009 10:21 AM
