Old 01-29-2007, 08:13 PM   #1
Bathroom repairs
I have a bathtub with the supply on the exterior rock wall. The condensate line for the AC runs under the tub to the AC unit located outside the Bathroom. In the past, I have had to unclog the condensate tube in the summer. Now the line is clear and there is water on the floor when they use the tub, and still a little when they don't. I removed the baseboard near the tub and it was wet.
I need to replace the Porc on Steel tub with a similar one, and repair the plumbing in the wall. I would like to remove only the supply side of the tiled shower; am I dreaming? I also tiled the bathroom floor, so there is a 3/8" edge at the tub.
Advise, please.
Tscarborough is offline   Reply With Quote
Old 01-30-2007, 08:02 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Bathroom repairs
Time to wake up. It will take more the one side of removal to get that tub out, is there a reason to replace the tub, can you not just find and fix this leak?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 01-30-2007, 09:48 AM   #3
Bathroom repairs
The tub is shot; our water is very hard. I was hoping to only tile the one wall, since all of the tile is fine, but I guess not.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Second level / attic bathroom size moneymgmt General Discussion 2 05-02-2007 08:32 AM
An idea on repairs? (Buying a Fixer Upper Home) kelly001 Building & Construction 15 10-03-2006 05:38 PM
