Bathroom Remodeling - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2006, 07:30 PM   #106
Ron, yes its vent to the tub. I am a little lost on the 45 angle? Thanks Nothing is glue yet, so this is the time for changes....
helpless handyman is offline   Reply With Quote
Old 08-20-2006, 07:40 PM   #107
Journeyman Plumber
Ron The Plumber's Avatar
Tilt the Santee at a 45 degree angle towards the wall, then use a 45 el to make it hoizontal then take it to the wall.
Ron The Plumber is offline   Reply With Quote
Old 08-20-2006, 07:49 PM   #108
Ouch! That means I am going to have to drill lower on the joist, so that I can have clearance from the top of the joist. I was trying to keep the pipe at its height, going up as it reaches the tub drain, this way the water flows freely to the stack.
Old 08-20-2006, 07:51 PM   #109
Journeyman Plumber
No you won't, turn the tee other direction, now tilt side of tee at a 45, add a st 45 el into the side of the tee and run it to the wall, keep drain where it's at.
Old 08-20-2006, 07:53 PM   #110
Journeyman Plumber
You can tilt it at 22 degree if you want and add a 22 of the side of that tee.
Old 08-20-2006, 07:57 PM   #111
Journeyman Plumber
Ok you are high in the floor, way are you so high in that floor?
Old 08-20-2006, 08:05 PM   #112
I am very high on the floor Ron because the drain stack is very high. They had ran lead pipes bang down on the floor, and I don't know how the water drained before. I didn't get a chance to use the tub, I guttered the entire house. If you look at the stack, the 2inc pipe is coming out very high, thats why I had a problem with the toilet drain, nothing worked, but the 4 to 3, to 4 method you advise me off. Thanks
Old 08-20-2006, 08:08 PM   #113
Journeyman Plumber
Ok then do this just turn the tee around, and go with it, you have no other options unless your ready to rebuild the stack, the vent for the tub will work like that, questiom is, will you get trap to work?
Old 08-20-2006, 08:08 PM   #114
Ron, if you look at the picture, you will see that they notched the top of the joist because the pipe was so high up.
Old 08-20-2006, 08:10 PM   #115
Journeyman Plumber
One more thing? What is the 90 on the lav drain, is that a Long Turn, Short Turn?
Old 08-20-2006, 08:10 PM   #116
Journeyman Plumber
I see it
Old 08-20-2006, 08:15 PM   #117
Short turn on lav drain. Wish I could post bigger picture, and you would be able to see them better..Is this okay? Your starting to frighten me... I have been framing and sheetrocking, and I am getting close to closing up the bathroom .
Old 08-20-2006, 08:17 PM   #118
Journeyman Plumber
Should be a Long Turn, but if there was no room for it, Short Turn will work.
So turn tee around and you ready to glue it up.
Old 08-20-2006, 08:23 PM   #119
No room buddy, your sure you don't want to fly to NY??? There is plenty of sight seeing out here...
Old 08-20-2006, 08:25 PM   #120
Journeyman Plumber
Not this year
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
kitchen and bathroom remodeling Grumpy Remodeling 11 02-10-2005 01:35 PM
