Bathroom Remodeling - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2006, 12:38 PM   #61
Ron, Thanks so much you've been a Great Help!!!!!
helpless handyman is offline   Reply With Quote
Old 08-03-2006, 02:20 PM   #62
Hey Ron, I couldn't let you go that easy!!! What will I need for the toilet drain, 4inc what? What type of flange? Thanks, also whats the inches on the stub out, on a toilet from the finished wall? Thanks again..
Old 08-03-2006, 05:52 PM   #63
Journeyman Plumber
Ron The Plumber's Avatar
Center of flange 12.5 from rough wall 12 from finish wall.
If 4" there now use a 4 x 3 rubber fernco, then a 3" PVC with a 90 and 4 x 3 PVC Schd 40 closet flange.
Ron The Plumber is offline   Reply With Quote
Old 08-03-2006, 08:50 PM   #64
Thanks Ron, also is it okay to do the entire vent and drain with 2inc? I was going back and fourth trying to get the 1 1/2 pieces and they were all out. So I purchashed everything 2 inc, vent and drain.
Old 08-03-2006, 09:09 PM   #65
Journeyman Plumber
Do they all end up at the 4" stack going to the roof?
Then yes nothing wrong with ir all being 2"
Old 08-03-2006, 09:21 PM   #66
Yes, the vent I am going to use is comming right out of the 4 inc stack, and yes its going rigt to the roof. I am going to cut the cast iron 2inc vent and continue with my 2 inc pvc vent. Also on the toilet, why are you suggesting to go from 4inc to 3inc, I'm curious? Thanks.
Old 08-03-2006, 09:23 PM   #67
Journeyman Plumber
Simple to work with the smaller size 3" over the 4"
Old 08-03-2006, 09:45 PM   #68
Will do, Thanks...
Old 08-03-2006, 09:47 PM   #69
Forgot to mention, the 4 inc pipe comming out of the stack was cut by an idiot, and he left only about 1 1/2 to 2inc of pipe to grab onto the fernco coupling. Will this leak in the long run?
Old 08-03-2006, 09:49 PM   #70
Journeyman Plumber
Should be fine, just make sure it's tight.
Old 08-03-2006, 09:58 PM   #71
Thanks a mill, that's been worry me!!! I looked at it, and flipped. I thought it wasn't long enough to grab the rubber coupling. Thanks again Ron for all your help.
Old 08-04-2006, 07:49 AM   #72
Hey Ron, forgot to mention, the 2 inc vent that you always asked whats this? I mark it on the drawing, that pipe(2inc) actually goes downstairs to the kitchen and it is the drain and vent for the kitchen sink. I will take pictures of it this weekend. I capped it off, after it goes downstairs.
Old 08-04-2006, 07:54 AM   #73
Journeyman Plumber
Make sure you keep kitchen connected to the venting, if the tub has a new vent relocated then just cap the old tub line near the tee that is there now.
Old 08-04-2006, 09:41 AM   #74
Will do, Thanks!!!!
Old 08-04-2006, 02:15 PM   #75
Hey Ron, I just saw this, and what you think it might work? Thanks
Basement bathroom remodeling amakarevic Building & Construction 2 04-12-2007 07:59 PM
kitchen and bathroom remodeling Grumpy Remodeling 11 02-10-2005 01:35 PM
