Bathroom Remodel, Sink Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2011, 07:33 PM   #1
Bathroom remodel, sink plumbing
I'm replacing the cabinets in the guest bathroom and have a question about plumbing for the sinks. The new cabinets are 3" taller than the older ones and the new sinks that are being installed are only 4" deep. To take advantage of the gain in under cabinet space, I need to move the existing plumbing within the walls up. The house is 25 years old and I suspect that over the years, some settling has already changed the pitch of the plumbing, resulting in many clogged drains (fill with some type of sediment goop). What is the optimal pitch of the plumbing from the sink drain (after the p-trap, within the wall) to the main pipes?
I'd love to fix this during the tear-out, take care of all of the drywall at one time, thanks for any help.
dschmid is offline   Reply With Quote
Old 02-03-2011, 08:04 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
1/4" per 1 ft of run
The slope of drain pipes needs to be a minimum of 1/4" of pitch per horizontal foot on run. If you can slope it more, that would be better. But you need at least 1/4" per foot.
adpanko is offline   Reply With Quote
Old 02-03-2011, 09:12 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 352
1/4" per ft is optimal. Too much slope and your liquids will move too fast and leave the solids behind. Too little grade and neither will move down the pipe properly.
Old 02-03-2011, 09:32 PM   #4
Thanks, that is great to know! Now to get started...
Bathroom Remodel Questions Vikeologist Remodeling 52 12-31-2009 10:13 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Bathroom remodel. New Shower Plumbing s4alex Plumbing 5 10-14-2008 07:40 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
Need Help Plumbing A Utility Sink... drummereef Plumbing 17 07-29-2008 04:16 PM
