Bathroom Remodel. New Shower Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2008, 11:42 PM   #1
Rewards Points: 14
Bathroom remodel. New Shower Plumbing
So, I am in the middle of a remodel. Finished up the electrical now I need to get the plumbing done so I can get the inspector out to do the first check.
So, now I am dry fitting all the copper fittings and have to make a choice.
My question is, does it matter if there are multiple couplings? Or should I try and use a single peice of copper?
I mean, should I solder and remove the pipe where there is an exiting connection or can I just cut a two foot section out and add a new section using couplers?
Main reason is that I am putting in a whirlpool and the valve and spout has to move up a few inches.
I guess is there an advantage or disadvantage to having less couplers? Or does it not even matter, especially if there is no current leak?
s4alex is offline   Reply With Quote
Old 10-14-2008, 12:59 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I personally do not see anything wrong with it, Its done all the time with remodeling,
Old 10-14-2008, 10:17 AM   #3
DIY'r
ScottR's Avatar
What Bob said ^^^
The only advantage with less fittings I could see is cutting down on the possibility of leaks.. But with properly sweated copper, it wouldn't concern me.
If you could eliminate a LOT of fittings, I'd say put in a fresh pipe for neatness sake. A few fittings, might as well save the $ and time and use what's there.
ScottR is offline   Reply With Quote
Old 10-14-2008, 10:37 AM   #4
Not a problem. More joints would allow more chances for leaks but this is rare if soldered properly. I would only change it if it were an exposed line and I didn't want to see extra joints.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-14-2008, 12:18 PM   #5
Rewards Points: 14
Great, that makes me feel better. I figured as much. I just didnt want to run into any issues with the inspector. The connectors seem to be done properly as there are no current leaks and seems as though there have not been any.
Atleast this saves me yet another trip to the bix box for two 10ft lengths of copper.
Old 10-14-2008, 06:40 PM   #6
buletbob's Avatar
just make sure you have it under pressure (water turned on ) when your finished sweating those couplings. I would also discharge some water from both hot & cold so to let the air out of the lines. do this before you close up the walls, with plumbing when ever you leave existing threaded fittings and you vibrate those pipes you have a greater chance of them leaking
good luck BOB.
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 01:15 AM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
Bathroom remodel.. shower floor tile lastcall916 Remodeling 3 02-25-2008 09:03 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Bathroom Tile Shower Remodel MattCoops Remodeling 2 04-30-2007 05:48 PM
