Bathroom Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2012, 07:21 PM   #1
Bathroom plumbing question
I'm in the process of dropping two water lines in my basement for a bathroom that's part of a basement finishing project. I've got the hot and cold lines coming down from the ceiling joists extending out through where the vanity will be. The toilet will be next to the vanity. Is it acceptable, (per code), to run another line off of the cold water line to use for the toilet? I guess I'm wondering if there has to be a separate cold line for the toilet or can it branch off the cold water line used for the vanity. This may seem like a pretty basic question, but I'm not real experienced with plumbing. Also, I'm using PVC pipe.
muehleisem is offline   Reply With Quote
Old 03-29-2012, 07:50 PM   #2
Experienced
Jackofall1's Avatar
What size are you running all this in?
PVC wouldn't be my choice, and how are you going to run from the vanity to the toilet, across the floor? along the wall? why not branch off in the wall and run to the back of the toilet?
Mark
Old 03-29-2012, 10:46 PM   #3
Rewards Points: 12,856
You need to be using CPVC, Pex or copper but not PVC.
Old 03-29-2012, 10:50 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Seconded. PVC is not allowed in the house.
Journeyman Plumber
Old 03-30-2012, 04:10 PM   #5
Sorry, I should have given more information. I'm doing the framing also and so the lines are already going through and along the studs. I'm using 1/2" CPVC, not PVC. I know copper is probably a better choice but that's what they used when the house was built. I'm just wondering if it's okay to run the toilet line off the vanity line.
Old 03-30-2012, 06:31 PM   #6
Rewards Points: 660
Yes.
B
Beepster is offline   Reply With Quote
Old 03-30-2012, 07:36 PM   #7
Rewards Points: 582
yes you can
Adding Basement Bathroom. Rear discharge toilet install question paulyjsob Plumbing 9 08-16-2014 02:59 PM
New DIYer - bathroom sink plumbing help AdeAhmed Plumbing 7 09-21-2011 10:18 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 05:14 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Raise Floor For Bathroom Plumbing Expansion ? fliteking Plumbing 1 11-16-2009 08:08 PM
