-   -   Bathroom plumbing question (http://www.diychatroom.com/f7/bathroom-plumbing-question-138681/)
muehleisem 03-29-2012 07:21 PM
I'm in the process of dropping two water lines in my basement for a bathroom that's part of a basement finishing project. I've got the hot and cold lines coming down from the ceiling joists extending out through where the vanity will be. The toilet will be next to the vanity. Is it acceptable, (per code), to run another line off of the cold water line to use for the toilet? I guess I'm wondering if there has to be a separate cold line for the toilet or can it branch off the cold water line used for the vanity. This may seem like a pretty basic question, but I'm not real experienced with plumbing. Also, I'm using PVC pipe.
Jackofall1 03-29-2012 07:50 PM
What size are you running all this in?
PVC wouldn't be my choice, and how are you going to run from the vanity to the toilet, across the floor? along the wall? why not branch off in the wall and run to the back of the toilet?
Mark
joecaption 03-29-2012 10:46 PM
You need to be using CPVC, Pex or copper but not PVC.
Alan 03-29-2012 10:50 PM
Seconded. PVC is not allowed in the house.
muehleisem 03-30-2012 04:10 PM
Sorry, I should have given more information. I'm doing the framing also and so the lines are already going through and along the studs. I'm using 1/2" CPVC, not PVC. I know copper is probably a better choice but that's what they used when the house was built. I'm just wondering if it's okay to run the toilet line off the vanity line.
Beepster 03-30-2012 06:31 PM
Yes.
B
ben's plumbing 03-30-2012 07:36 PM
yes you can:yes:
