Bathroom Pipes In Cement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2011, 03:58 PM   #1
bathroom pipes in cement floor
What are the slope measurements in inches per foot? And if using pvc pipe what kind of protection do they need before pouring cement?
jodine is offline   Reply With Quote
Old 01-05-2011, 07:25 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 774
1/4" per ft. grade.
Any pipe should not contact concrete. I like to use "sill seal" insulation. Thats the thin foam thats used on top of concrete walls under the sill plate. A couple wraps will do. secure with duct tape
Can't replace sub floor due to pipes PeterMa Remodeling 2 04-25-2010 10:18 AM
2nd floor bathroom OSB subfloor replacement? blargh Flooring 0 04-07-2010 02:31 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 06:30 PM
Cement only floor? Will I have problems? Brokefoot2 General DIY Discussions 4 09-30-2007 11:09 PM
