Bathroom Hot Water Line In My Bathroom Is Blocked - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2012, 07:51 PM   #1
Bathroom hot water line in my bathroom is blocked
how to unplug my hot water line in my bathroom sink
Soniafails is offline   Reply With Quote
Old 10-14-2012, 08:05 PM   #2
Rewards Points: 13,300
How do you know it's pluged up?
Did you disconnet the line under the faucet and run some water into a bucket?
Made sure the valves open ?
Old 10-14-2012, 10:48 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
In my recent spat of plumbing for my addition....I was moving and connecting copper lines....in the process I got some junk stuck in the faucet in the kitchen....
I turned off the hot water at the water heater....disconnected the hot flex hose going to the water heater....I then turned on the faucet to half hot/cold....this forced cold water down the hot side....let it run for awhile....
In then laundry room I looped hot to cold at the box for the washer...(other end of my hot water line)...and flushed the hot line out again.
Problem solved.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Leaky ball valve at incoming water line Bipin1948 Plumbing 5 10-03-2011 06:21 PM
Water supply line blackhemi Plumbing 4 04-09-2011 09:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
