Bathroom Floor Wet; Water Coming _out_ Of Bath Overflow. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2008, 04:07 PM   #1
Bathroom floor wet; water coming _out_ of bath overflow.
Came home this evening to find the bathroom floor flooded. Noticed a weird thing - water was coming _out_ of the bath overflow, into the bath and down the plughole. I presume this is causing the leak, but have no idea how. Anyone got any ideas? I've turned off the water but don't want to rip the bath's side off yet.
Regards,
P.
oceanclub is offline   Reply With Quote
Old 01-09-2008, 03:48 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The overflow and the tub drain are connected and share the same trap and drain pipe.
The only way that I know of for water to be coming out of the overflow is for the drain line or the trap itself to be clogged.
Is the water ON when the overflow is leaking?
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-09-2008, 04:37 AM   #3
Once I'd mopped up all the water, I noticed that the toilet cistern was dripping. When I checked, I found that the outflow pipe from it was leaking; it's not securely sealed to the cistern. And the reason why there's so much water outflowing is because the ballcock is broken! So 2 things at once resulted in the leak.
Even with the water shut off, there's still a dribble of water coming into the tank (leaky seal somewhere else?) so I had to whittle a wine cork down to plug the inlet (and no reason to waste the wine afterwards).
Thanks for the response,
P.
Old 01-09-2008, 08:42 AM   #4
The fill valve may need to be replaced.
redline is offline   Reply With Quote
Old 01-09-2008, 06:46 PM   #5
Send a message via AIM to Marlin
Mike
It's actually not possible for the overflow to leak in the way he described. The tub would fill up with water just as fast as the pipe leading to the overflow filled up.
Marlin is offline   Reply With Quote
Old 01-09-2008, 06:47 PM   #6
It sounds like the fill valve is doing it's job. The tank is empty so it's trying to fill it. The valve for the toilet needs to be changed.
Old 01-09-2008, 10:47 PM   #7
Master Plumber
Rewards Points: 150
Sounds like the wine is doing it's job.
The only possible way I can picture water coming out of an overflow plate on the tub and going down the drain is with a trip lever stopper with gunk plugging the pipe on top of the stopper because of a condensate drain tied into the back of the overflow tube....but it is winter time, are you running your air conditioner?
jpplumber is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 06:34 AM
Prevent potential water from the bathroom peter1 Flooring 4 05-15-2007 08:02 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
