Bathroom Faucet Water Running - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 04:44 PM   #1
Bathroom Faucet water running
I'm installing a new faucet. I've gotten through everything and when I go to turn on the hot and cold water lines, the cold water runs. It runs even though the cold water handle is in the off position.
What's the deal?! Help!
Youngsie is offline   Reply With Quote
Old 02-25-2012, 04:51 PM   #2
Rewards Points: 13,274
No idea, make, model?
Single handle double handle?
If it's single handle are you 100% sure it's not installed backwards. Easy to do. Hots on the left, correct?
Old 02-25-2012, 05:17 PM   #3
Rewards Points: 582
sounds to me you installed handle in wrong position....remove handle......turn stub to off position reinstall handle...
Old 02-27-2012, 05:47 PM   #4
Fixed!
Correct!
I turned the handle, removed the handle, replaced and turned again. I noticed the copper piece was the part that was moving. Removing the handle again, I turned the copper piece into the "off" position and then replaced the handle.
Everything now works...Thanks for your responses.
The Following 3 Users Say Thank You to Youngsie For This Useful Post:
ben's plumbing (02-27-2012), jaydevries (02-27-2012), oh'mike (02-27-2012)
Tags
bathroom , faucet , installation , plumbing
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
Anti Siphon faucet spewing water cai Plumbing 1 08-01-2011 03:48 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 08:46 AM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 06:38 PM
