Old 02-26-2011, 04:54 PM   #1
bathroom faucet pop-up lets water go down
My plumber installed my new Delta Dryden faucet with the pop-up drain. Problem 1 - When the pop-up rod is pulled up, it does not keep the water from going down when there's water in the sink.
Problem 2 - When the water is running with the pop-up down so the water can go down the drain, after the sink gets filled 1/3 or more with water, the weight of the water makes the pop-up "pop up" even if not pulled up in the pop-up position, and the water can't go down normally and only drains extremely slowly. My plumber said the pop-ups never work - but all mine have in the past.
bluebath is offline   Reply With Quote
Old 02-26-2011, 07:35 PM   #2
call me E
TheEplumber's Avatar
insist that your plumber to come back and fix it or supply a different pop-up. You're right, they do work
The Following User Says Thank You to TheEplumber For This Useful Post:
bluebath (02-27-2011)
Tags
pop-up
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Low hot water pressure in bathroom. Craive Plumbing 3 03-23-2010 07:58 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 07:40 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
