Bathroom Faucet Low Water Flow - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2008, 05:37 PM   #1
My bathroom was converted from single vanity sink to double vanity sink. Plumbing lines to the two faucets were connected from the existing water line. One faucet has good water flow while the other faucet has a very low water flow. What is causing this?
Ricardo
domesticproperties is offline   Reply With Quote
Old 07-27-2008, 05:47 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Mostly likely just debris in the faucet aerator screen.
Remove the aerator and clean it out. Run the faucet without the screen to clean out the line before replacing it.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-27-2008, 06:01 PM   #3
Bathroom Faucet Low pressure
Thanks for your quick response. I will try that.
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
water flow problem copwk Plumbing 2 07-27-2008 07:12 PM
Help! hot water won't stop running despite faucet changes. nodak_luke Plumbing 4 12-14-2007 05:38 PM
No water coming from main water line in bathroom sassylaroo Plumbing 6 10-29-2007 05:34 AM
