Bathroom Faucet Handles - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-12-2012, 09:01 AM   #1
bathroom faucet handles
my bathroom faucet is leaking and i am trying to remove the handle to attempt to replace what ever the problem is and i can't seem to get the handles to budge. i removed the screw on the handle it self but these things wont budge at all i sprayed the opening and all around the handle with wd-40 and let it sit and tried and still nothing. So the following day i went to homedepot and purchased CLR and handle puller but still wont budge. The handle puller wont fit under the handle but even after spraying it with clr it wont budge. Any ideas maybe there is another screw i'm not seeing?
I even went to great lengths to remove everything underneth but got stuck at this joint and couldnt break it loose.
So right now its all put back together and leaking still
TIA
typo is offline   Reply With Quote
Old 11-14-2012, 06:45 AM   #2
i have been looking on alot of the common faucet websites moen, american standard and kholer but cant find this faucet.... Any advice would be great. I'm hoping i don't have to cut it off and replace it.
Old 11-16-2012, 06:59 PM   #3
Barry
What about loosening or removing that black nut up underneath? When you say you removed the screw on the handle I assume you mean the set screw in the little hole on the stem?
Tub Refinisher is offline   Reply With Quote
Old 11-16-2012, 07:24 PM   #4
yes i removed the set screw. i even tried pb blaster and still wont come off. the black plastic nut that holds the handle to the sink comes loose but go past the metal elbow. And i cant get the metal elbow to come loose not sure really how i can get it loose either. i tried channel locks and some muscle but it was a no go.
Old 11-16-2012, 07:39 PM   #5
Rewards Points: 558
You have to remove that elbow in order for the handle to come out completely. Use a dremel tool to cut it off where the thread is..
epson is offline   Reply With Quote
Old 11-16-2012, 07:40 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Is there a cap on top of the handle that you could pry off? Maybe a screw under it.
sublime2 is offline   Reply With Quote
Old 11-16-2012, 07:46 PM   #7
no other screw or cap. epson so is that elbow semi sealed? and needs to be cut off?
Old 11-16-2012, 07:52 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 806
Don't cut anything under the sink. You'll be buying a new faucet
Old 11-16-2012, 07:54 PM   #9
Plumber
Rewards Points: 806
does the square bonnet rotate when you turn the handle?
Old 11-16-2012, 07:59 PM   #10
Rewards Points: 558
Sorry my bad, I miss read your post. Please don’t cut it off or you’ll be buying a new one.
No, you just have to try harder as it’s threaded on.
Old 11-16-2012, 08:13 PM   #11
it does spin but i can only spin it so far then it stops. i tried to spin it using it to force the handle off but it was a no go.
No flow from bathroom faucet Baylark Plumbing 1 02-26-2012 07:37 AM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 06:16 PM
LED bathroom faucet drtbk4ever Plumbing 16 02-10-2010 08:11 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 07:55 PM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
