Bathroom Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-11-2010, 08:04 PM   #1
Bathroom Faucet
Hi - hope you can help me.
I had a leak from the bathroom faucet so I changed the O rings on the hot side. Then a piece of plastic fell off the stem so I replaced that. This a Delta two handle wide spread faucet. The issue is that the faucet does not control the water flow now that I've turned on the valve. There is no on/off from the handle. I have turned the water off at valve.
Can someone suggest a remedy?
rrizz is offline   Reply With Quote
Old 04-11-2010, 08:21 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome.
Did you make sure the cartridge went back in the right way after you replaced the o-ring?
Pull it again, turn it 180 and replace it. Test again.
DM
Old 04-11-2010, 09:30 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
MOEN
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
rrizz (04-11-2010)
Old 04-11-2010, 09:35 PM   #4
Just tried that and nothing changed. I'm not able to regulate the water flow with the handle.
Old 04-11-2010, 09:44 PM   #5
did you make sure the seat and spring went in correctly?
plumber Jim is offline   Reply With Quote
Old 04-12-2010, 04:28 PM   #6
I never touched the seat and spring...never really knew they were there.
Old 04-12-2010, 04:40 PM   #7
fabrk8r
fabrk8r's Avatar
Does this help?
http://www.deltafaucet.com/customers...iterature.html
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-12-2010, 05:03 PM   #8
Thanks this helps in that tells me the faucet is discontinued. It does provide product and parts numbers. Thanks.
Really looking for a cause of why the faucet does not regulate the water flow.
Old 04-12-2010, 07:32 PM   #9
fabrk8r
fabrk8r's Avatar
1-800-345-delta (3358)
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 01:13 PM
Dripping two handle bathroom sink faucet? hzemall Plumbing 1 09-06-2009 06:51 PM
Leaky Bathroom Faucet w No Markings cmcwittig Plumbing 6 12-23-2008 09:55 PM
Bathroom Faucet Low Water Flow domesticproperties Plumbing 2 07-27-2008 06:01 PM
Installing new bathroom faucet CathrynH Plumbing 7 01-13-2008 11:00 PM
