Old 07-06-2008, 07:12 PM   #1
Send a message via AIM to Boughamer Send a message via Yahoo to Boughamer
Bathroom drains
I have a bathroom with two drains on the same line. They drained well before. Now since a drain for the A/C was added to the vent in the attic they do not drain hardly at all. I have the same problem in the master bath with the sink the vent also has a drain for the A/C also. I am thinking the drains are blocking some of the air flow, would that be a good assumption? How do I fix it? Can I put a vent under the sink? Any answers would be greatly appreciated. As I hate to assume (It makes an A@s out of you & me) Thanks in advance for the help!
Boughamer is offline   Reply With Quote
Old 08-02-2008, 05:20 PM   #2
Send a message via AIM to Marlin
Bathroom drains
Putting a pro vent under the sink will work (for the sinks anyway) however it's just slapping a band aid on the real problem. Can you take a picture of how this drain was tied into your vent? They must have done something improperly or dropped something down the vent line to clog it.
Marlin is offline   Reply With Quote
Old 08-03-2008, 11:41 AM   #3
Bathroom drains
I found the problem, I ran a snake through it, it was algae/slime that plugged up the drain. It was so bad on the double sink that I had to run it through the vent on the roof to get it unclogged.
The A/C drain line is hooked in to the vent for the plumbing and I guess that is what caused my problem, will be running my A/C drains to somewhere different to fix that problem, Thanks for the reply back Marlin, I appreciate it.
Thanks,
Boughamer
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 12:44 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
Second level / attic bathroom size moneymgmt General Discussion 2 05-02-2007 08:32 AM
