Bathroom Double Lav Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 03:54 PM   #1
bathroom double lav venting
I'm installing 2 lavs/sinks on a 54 inch double vanity. Is each lav/sink required to have its own separate (1-1/4) p-trap, or can I connect them together with 1 (1-1/2) p-trap before they connect to the 1-1/2 waste stack? My municipality uses 2006 Nat Standard Plbg Code.
thank you
rcassidy is offline   Reply With Quote
Old 09-09-2010, 04:41 PM   #2
I prefer to have each sink individually trapped, but they can run to a common drain/vent in the middle. my code says 1 1/4" for each drain, 1 1/2" for the common drain and vent (UPC) make sure the trap arm isn't more than 2'6" if you use 1 1/4" pipe. Most ppl use 1 1/2", trap arm can be 3'6"
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
TheEplumber (09-09-2010)
Venting a bathroom Cossack Plumbing 10 06-27-2010 04:07 PM
basement bathroom drain venting tbru Plumbing 2 01-17-2010 06:30 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 04:44 PM
3rd Floor Bathroom Not Venting FEDERAL GOON Plumbing 4 06-15-2008 08:35 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
